HullAccumulator
Creates a convex or concave hull based on a group of input features.
Creating hull geometry over multiple features.
The HullAccumulator receives features with geometry and calculates either a Convex or Concave hull around them.
A convex hull is a polygon covering the extents of all features, where no interior angle is greater than 180 degrees. It resembles an elastic band surrounding the features.
A concave hull (or alpha hull) has no restrictions on angle and may follow the general shape of the data more tightly. It is calculated using the Alpha Value parameter and can have multiple parts and donuts.
If an output hull has zero area (the hull of a single point or vertical line, for example), it will become a point or line as appropriate.
3D hulls may be generated when input features are either 3D or a mix of 3D and 2D. If mixed, 2D features are assigned a default Z value.
Concave hulls and alpha values
Concave hulls vary in shape. They are calculated by first triangulating the dataset, then measuring the circumradius of the resulting triangles (the radius of a circle that touches all three points of the triangle). Triangles that are larger than the specified Alpha Value are discarded, and the rest are dissolved to form the hull. Measurements are in ground units.
If the Alpha Value is explicitly specified, it is used for the calculation. If it is zero (0) or not specified, the alpha is approximated as the smallest value that produces a single area. If the alpha is too small it may return a null geometry. Larger numbers generally produce larger areas, and a large enough alpha value produces the same result as a convex hull.
See Examples below to see the effect of varying the Alpha Value.
Geometries that are farther away than Alpha Value from the rest of the geometries may be discarded if they do not constitute a valid area on their own.
Concave hull generation works best with points, but line and area geometries will be accepted and converted to points if input.
In this example, we have a set of address points and want to generate a convex hull around them.
The features are routed into a HullAccumulator.
In the parameters dialog, Hull Type is Convex ().
The output hull contains all input features.
In this example, we will generate a series of concave hulls for a set of property addresses while varying alpha values.
The input features are in a UTM83-10 coordinate system, with ground units in meters, and so the alpha value represents a measurement in meters as well.
Alpha Value |
Concave Hull |
10 - Too small for useful results. |
50 - Tightly fitting, some input points fall outside alpha distance. |
Default (blank) - optimal value calculated to produce a single area. |
500 - Loosely fitting but not convex. |
10000 - Identical to the convex hull. |
- Point clouds are considered single features. To create a hull from a point cloud’s individual points, use a PointCloudToPointCoercer beforehand, setting the Output Geometry parameter to either Single Multipoint or Individual Points.
For triangulated surfaces, see the SurfaceModeller, Triangles output.
Features with 2D and/or 3D geometry.
Arcs and ellipses will be stroked prior to the calculation of the hull. Text features will be treated as points.
Hull geometry as specified in parameters. Typically a polygon, but possibly a line or a point.
Features without valid geometry are output via this port, as are features with non-numeric values for Alpha or Default Z Value.
INVALID_GEOMETRY_VERTICES
INVALID_PARAMETER_ALPHA_VALUE
INVALID_PARAMETER_DEFAULT_Z_VALUE.
Group By |
If Group By attributes are specified, a hull output feature is generated for each set of input features that have the same values for all those attributes. Otherwise, a single feature representing the hull of all input features is output. |
Complete Groups |
Hull Type |
Select the hull type to be calculated:
Alpha Value |
When Hull Type is Concave)(, either:
See Examples above for alpha value usage. |
Accumulation Mode |
Drop Incoming Attributes: The hull receives no attributes. Merge Incoming Attributes: The hull receives all attributes from input features. Use Attributes From One Feature: The hull receives all attributes from one representative feature. |
Output |
Select the dimensionality of the output hull:
Default Z Value |
When Output is 3D, provide a Z value to assign to converted 2D features. |
Dialog Options - Tables
Yes |
| Aliases | ConvexHullAccumulator |
Search for all results about the HullAccumulator on the FME Community.
