HTTPCaller
Accesses a URL via HTTP or HTTPS, using a variety of HTTP methods.
Available methods include:
HEAD
GET
PUT
POST
DELETE
OPTIONS
PATCH
COPY
LOCK
MKCOL
MOVE
PROPFIND
PROPPATCH
UNLOCK
CHECKOUT
CHECKIN
UNCHECKOUT
LINK
UNLINK
Import from OpenAPI Specification
Requests may be imported from APIs that provide an OpenAPI specification JSON or YAML file. To do this:
Download the specification file
Use the Import > Import from OpenAPI Specification button to access the import dialog
Provide the file location in the Specification parameter
Select from the available endpoints, and the HTTPCaller dialog will be populated as specified, including Request URL, Authentication Method, and request details such as HTTP Method and Query String Parameters.
Note that any selections made here will overwrite current parameter values.
This example uses an OpenAPI example specification to populate the HTTPCaller.
The example JSON file has been downloaded from OpenAPI.
Use the Import button, Import from OpenAPI Specification.
After providing the file location, the spec is loaded and available Endpoints are listed.
Our selection provides a Request URL, sets HTTP Method to GET, and populates some Query String Parameters. Authentication was not required.
The HTTP response body may be saved to an attribute, or a file. By default the body is saved to the attribute identified by the Response Body Attribute parameter.
The HTTP response status code will be stored in the attribute named by the Status Code Attribute parameter. By default this is the _http_status_code attribute. For more information on HTTP Status Codes, please refer to https://www.w3.org/Protocols/rfc2616/rfc2616-sec10.html.
In addition, the HTTP response headers will be saved in the list attribute specified by the Multipart Header List Attribute parameter. By default the headers are stored in the _headers{} list attribute. For a list of common HTTP response headers, please refer to https://en.wikipedia.org/wiki/List_of_HTTP_header_fields.
If an error occurs while accessing the URL, the feature will be output via the <Rejected> port. In addition, an error message will be set in the attribute named by the Error Attribute parameter.
Request URL |
This parameter identifies the URL which will be accessed by the transformer. The transformer can access http and https URLs. The URL can be entered directly in the transformer, or be built up from attribute values. |
HTTP Method |
Select an HTTP method to access the server. Most requests will use the GET method. Requests that upload data will typically use the PUT, POST or PATCH method, although an upload body can also be provided with the DELETE method. The HEAD, DELETE, and OPTIONS methods can be useful when accessing a REST API. Additional methods are available. |
Use Authentication |
If enabled, provide authentication details as needed.
Query String Parameters |
This table can be used to create additional URL query parameters. The parameters will be appended to the URL given in the Request URL parameter. This can be useful when accessing a REST API endpoint which requires many parameters. The parameter names and values can be entered directly or constructed from attribute values. |
Headers |
This table can be used to create custom HTTP headers which will be sent along with the request. This can be used to customize the request that FME will make to the server. Header names and values can be entered directly or constructed from attribute values. In addition, the Name column provides a list of commonly used header names. |
Body |
These parameters are only enabled when HTTP Method is PUT, POST, DELETE, or PATCH. An upload body is not required; for example, DELETE requests often have no upload body.
Save Response Body To |
This parameter allows users to set the destination for the HTTP response body. The body may be saved to an attribute, to a file specified by the user, or to a new file in a directory specified by the user. Note If you are downloading a very large response body with the HTTPCaller, it is recommended that you save it to a file. This avoids creating a large attribute on the feature.
Save Response Body To Attribute |
When this option is selected, each HTTP response body will be saved to an attribute of the feature which made the request. The following parameters are enabled for this option.
Save Response Body To File |
When this option is selected, each HTTP response will be saved to a file. The following parameters are enabled for this option.
Save Response Body To Folder |
When this option is selected, the HTTPCaller will create a new file for each feature that is processed.
Response Header and Status Attributes |
Multipart Response Handling |
It is rare, but possible for an HTTP server to return a multipart response. That is, a single HTTP request will result in an HTTP response which contains several different parts. A multipart response will have a Content-Type header which begins with "multipart", such as "multipart/mixed". The HTTPCaller has the Feature Output option to split such responses into multiple features. Because multipart responses are very rare, the default behavior is to not split multipart responses into multiple features. These parameters are only enabled when response bodies are being saved to attributes, or to a folder.
Concurrent Requests |
Retry Failed Requests |
When enabled, the HTTPCaller will attempt to retry requests which have failed, or have returned an HTTP error.
Rate Limiting |
HTTP Client Options |
Advanced Security |
Specification |
Specify a JSON or YAML OpenAPI specification file to use. This file must be downloaded (URLs are not supported). |
Select Endpoint |
Select an available option to have its details populated in the main parameter dialog. |
Dialog Options - Tables
This transformer replaces the HTTPFetcher, HTTPUploader, HTTPFileUploader, HTTPMultipartUploader, HTTPDeleter and HTTPHeader transformers.
Search for all results about the HTTPCaller on the FME Community.
Keywords: URLFetcher
