FMEFlowLogFileRetriever
Accesses the translation log for a specified FME Flow-run translation.
The translation log to access is identified by the job ID input parameter.
This transformer requires an FME Flow connection.
The initiating feature is output via the Succeeded port if the translation log was successfully retrieved for the specified job ID, and will have these attributes added to it:
- _log_attr: the contents of the translation log for the specified job
The feature will be output via the Failed port if the translation log was not successfully retrieved for the specified job ID, and will have these attributes added to it:
- _job_failure_type: contains the reason for the translation log retrieval failure
- _log_attr: the contents of the translation log for the specified job, obtained before an error occurred
Connection |
You can connect to FME Flow in one of the following ways: Specify a web connection to FME Flow. Web connections can be reused in multiple workspaces, and connection parameters are hidden in the workspace. For more information, see Using Web Connections. SAML Authentication SAML (Security Assertion Markup Language) authentication is not available for these FME Flow transformers: See SAML Configuration and Automations for more information and alternatives. When checked, you must specify the connection parameters to FME Flow manually. The connection parameters are visible in the workspace. To connect, specify: Enter a URL to access FME Flow. You may need to contact your System Administrator for the URL. Provide your FME Flow credentials. Note You can click the Status hyperlink to ensure that the FME Flow connection has been successfully established.
Job ID |
This parameter is the job ID of the translation log that is to be requested. |
Retrieved Log |
Name the attribute to contain the translation log. |
Dialog Options - Tables
Search for all results about the FMEFlowLogFileRetriever on the FME Community.
