CoordinateConcatenator
Retrieves the values of all the feature's coordinates into a single string attribute value, separated by delimiters.
Jump to Configuration
The CoordinateConcatenator receives point, line, area, or donut features and extracts their coordinates into one concatenated and delimited string attribute value.
The delimiters between coordinates and between elements of a coordinate (x, y, and z) may be specified, and can be special characters such as tabs or carriage returns.
Coordinates to include (x, y, and/or z) may be selected. If z is requested on features without z coordinates, it will be ignored.
Aggregates are not supported.
Example: Concatenating coordinates on area geometries
In this example, we have a shapefile of parks, and want to extract their coordinates into an attribute. Note that they are in a UTM coordinate system, with ground units in meters.
The features are routed into a CoordinateConcatenator.
In the parameters dialog, the default settings are kept. Note the delimiters - pipe (|)and comma (,).
X, Y, and Z coordinates are requested by default. Our data is 2D, so the Z will be ignored and these default settings are fine.
The output features have a new _coordinates attribute.
On closer examination of the attribute value, we see the coordinates of the polygon, separated by pipe delimiters. Note that the first and last coordinate are identical - indicating a closed area.
Example: Using special characters as delimiters for formatting
We can use special characters as delimiters to control formatting.
Using the previous example, in the parameters dialog, we access the Text Editor via the dropdown menu on the Coordinate Delimiter parameter.
The default pipe delimiter is replaced with a carriage return character.
The output attribute value now contains coordinates separated by line, which could be written to a text file with an AttributeFileWriter or used elsewhere.
Input
Features with point, line, area, or donut geometry.
Output
Features with coordinates added to an attribute as specified in parameters.
General
Specify a character or string to be inserted between each set of coordinates.
Coordinate Element Delimiter
Specify a character or string to be inserted between each component (x, y, z) of a set of coordinates.
Coordinate Element(s) to Include
Select which elements of a coordinate - x, y, and/or z - to include.
If z coordinates are requested, but the data is 2D (has x and y only), z will be ignored.
Output Attribute Name
Concatenated Coordinates
Name the attribute to store the resulting coordinate values string.
How to Set Parameter Values
Text Editor
Arithmetic Editor
Dialog Options - Tables
- Add a row
- Remove a row
- Move current row up one
- Move current row down one
- Move current row to top
- Move current row to bottom
- Cut a row - delete and copy to clipboard
- Copy a row to the clipboard
- Paste a row from the clipboard
Cut, copy, and paste may be used within a transformer, or between transformers.
Start typing a string, and the matrix will only display rows matching those characters. Searches all columns. This only affects the display of attributes within the transformer - it does not alter which attributes are output.
Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies |
None |
Aliases |
History |
The is the place for demos, how-tos, articles, FAQs, and more. Get answers to your questions, learn from other users, and suggest, vote, and comment on new features.
Search for all results about the CoordinateConcatenator on the .
