BoxConnector
Accesses the Box file storage service to upload, download, or delete files and folders or list file/folder information from a Box account.
- Manage datasets on Box by uploading, downloading, and deleting files and folders
- Transfer a file's contents (such as XML or raster) into or out of an attribute in FME
- Read downloaded Box data using the FeatureReader, or upload data written by the FeatureWriter to Box
- Retrieve file and folder names, paths, links and other information from Box to use elsewhere in a workspace.
The BoxConnector uses your Box account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer) to access the file storage service.
Depending on your choice of actions, it will upload or download files, folders, and attributes; list information from the service; or delete items from the service. On uploads, link attributes can be added to the output features. On List actions, links and file/folder information are added as attributes.
- This transformer cannot be used to directly move or copy files between different Box locations. However, multiple BoxConnectors can be used to accomplish these tasks.
- The FeatureReader can access Box directly (without using the BoxConnector), however, a local copy of the dataset will not be created.
The output of this transformer will vary depending on the Box Action performed.
- After an Upload action, URLs to the file may be saved to the Sharable Link and Direct Download Link attributes, and the ID of the file will saved to an attribute.
- A Download action can save to either a folder or attribute.
- A Delete action has no output ports.
- Finally, a List action will output a new feature for each file/folder found in the path specified. Each of these new features will have attributes listing various pieces of information about the object.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Box Action |
The type of operation to perform. Choices include:
Box Account |
Performing operations against a Box account requires the use of OAuth2 authentication using a Web Connection. To create a Box connection, click the 'Box Account' drop-down box and select 'Add Web Connection...'. The connection can then be managed via Tools -> FME Options... -> Web Connections. |
The remaining parameters available depend on the value of the Request > Box Action parameter. Parameters for each Box Action are detailed below.
Box Path
Delete as |
Select whether to delete a File or Folder.
Object ID |
The Object ID of a file or folder on Box to delete. If valid credentials have been provided as a web connection, you may browse to a location. |
Box Source
Object ID |
The Box ID of the file/folder to download. If valid credentials have been provided as a web connection, you may browse to a location. |
Destination
Download as |
Select whether to store the downloaded data in a File, Folder or Attribute.
Download to Folder |
Specify the path to the folder that will store the downloaded file. Valid for Download as File or Folder. |
Include Subfolders |
Choose whether to download subfolders of the Box Source or not. Valid for Download as Folder only. |
Download to Attribute |
Specify the attribute that will store the contents of the downloaded file. Valid for Download as Attribute only. Note FME will attempt to convert the attribute's contents to a UTF-8 string. If this fails, the attribute's contents will be created as raw binary. To ensure that the original bytes are always preserved and never converted to UTF-8, use Download as File instead.
Output Attributes
Attributes to Add |
The selected attributes will be added to the output feature.
Box Path
Generate Sharable Link |
Specify this option to retrieve the File or Folder Link attribute. This will allow content to be viewed and/or downloaded by anyone with access to these links. |
Folder ID |
The folder ID on Box to list the contents of. If valid credentials have been provided as a web connection, you may browse to a location. |
Output Attributes
Attributes to Add |
Source
Upload |
The type of data to be uploaded.
When working with large objects, File is a better choice than Attribute as the data will be streamed directly from disk and not require that the object be stored entirely in memory on a feature. Box treats file uploads of the same name, in a specific folder, as duplicates, but does not allow multiple instances in a specific folder. You must upload the file to a different folder than the existing one. When wanting to upload content from a folder, it is better to upload as a folder instead of setting a fixed path and sending multiple features into the connector to upload as a file. |
Generate Sharable Links |
Specify this option to set the Shared and Direct Download Link Attributes. This will allow uploaded content to be viewed and/or downloaded by anyone with access to these links. |
File to Upload |
The file to be uploaded to Box if Upload is set to File. |
Folder to Upload |
The folder to be uploaded to Box if Upload is set to Folder. |
Choose whether to upload subfolders of the Folder to Upload or not. |
Attribute to Upload as File |
The data to be uploaded, supplied from an attribute if Upload is set to Attribute. |
Box Destination
Folder ID |
The path on Box to upload the source file to. To upload to the root directory, enter “/”. |
Upload with File Name |
The name of the file created from the data supplied in Attribute to Upload as File. The name must include a filename extension (for example, .txt, .jpg, .doc). |
Output Attributes
Attributes to Add |
Dialog Options - Tables
| Dependencies | Box account |
| History | Released FME 2017.0 |
Search for all results about the BoxConnector on the FME Community.
