AttributeTrimmer
Removes specified leading and trailing characters from selected attributes.
- Cleaning attribute data
- Removing white space (non-printing characters) from attribute values
The AttributeTrimmer removes specific characters from the beginning and/or end of chosen attribute values.
It does not match specific character patterns, rather, as long as the next character is included in the list of Trim Characters, it will continue to remove them until it encounters a character that is not in the list.
For example, suppose the attribute to trim had the value "This is a test" and Trim Type was set to Both (trimming from both the beginning and end of the value).
- If Trim Characters had the value "hit", the result would be "This is a tes".
- If Trim Characters had the value "HhIiTt", the result would be "s is a tes".
Trim Characters may be alphanumeric, and can include control characters. If Trim Characters is left blank (unspecified), “white space” will be removed - non-printing characters such as spaces, tabs, newlines, and carriage returns.
The attributes are output with any matching characters trimmed. Attributes that do not have matching Trim Characters are output untouched.
In this example, we start with a CSV file containing animal names and counts. Some animal names have varying numbers of extra spaces that need to be removed.
All features from the CSV file are routed into an AttributeTrimmer.
In the Parameters dialog, we select the attribute Animal for trimming, choose Trim Type Both to trim both the left and right-hand sides of the values, and leave the Trim Characters field blank - indicating we want white space removal.
The resulting output has clean Animal values, with spaces removed.
In this example, we start with a list of codes. They are all prefixed with the string UID-, and we wish to remove that prefix from the values.
The features are routed into an AttributeTrimmer with the intention of removing the prefix.
In the Parameters dialog, we select Trim Type as Left (the location of the prefix), and enter the prefix string UID- as the Trim Characters.
In the output file, the prefixes have been removed - but unfortunately, some additional characters have been trimmed as well. Because the AttributeTrimmer is not looking for a specific pattern of characters, if the first character(s) to the right of the prefix match any characters in the Trim Characters string, they will be removed as well.
As highlighted in the CorrectResults list, some of the initial characters beyond the prefix matched the Trim Characters.
A better choice to perform this task would be the StringReplacer, which will look for the exact pattern of the prefix.
- To trim a specific prefix or suffix, or match any consistent string pattern, consider using the StringReplacer.
Features with attributes you wish to trim.
Features with the selected attribute(s) trimmed according to your parameter selections, and all other attributes unmodified.
Attributes to Trim |
Select the attribute(s) to be trimmed. |
Trim Type |
Characters may be trimmed from the right, left, or from both sides. |
Trim Characters |
Enter individual characters to be trimmed. Characters will be trimmed from beginning, end, or both the beginning and the end, depending on the Trim Type selection. The trimmed characters are case sensitive. If you do not specify a trim character, white space is removed (spaces, tabs, newlines, and carriage returns). Characters can be expressed as regular characters but they can also include any number of control characters. Special character sequences are interpreted as shown below:
Defining Special CharactersYou can define special characters through the Text Editors. Click Open Text Editor from the parameter menu:
Text Editor Enter characters using the shortcuts from the table above. Note To see tab characters, click the Options menu on the bottom left and select Show Spaces/Tabs.
Note This parameter is not a text string that is matched and removed. To remove an entire text string, use the StringReplacer.
Allow Trim Down to Nothing |
If a given attribute value contains only Trim Characters, the character that remains depends on the Trim Type: for Both it will be the middle character, for Left it will be the last character, and for Right it will be the first character. If the Allow Trim Down to Nothing option is set to No, the output of the trimming will have at least one character remaining. |
Dialog Options - Tables
| Dependencies | |
| Aliases | StringTrimmer |
Search for all results about the AttributeTrimmer on the FME Community.
