2DGridAccumulator
Creates a regular grid of points or rectangular polygons that span the extents of all input features.
Generating grid for a specific dataset’s coverage
Creating reference grid in conjunction with a Tiler or RasterTiler
The 2DGridAccumulator receives features with geometry and creates a regular grid that covers the bounding box containing all features.
The grid may be composed of:
rectangular polygons,
points at the corners of each cell, or
points at the center of each cell.
Cell size may be either specified explicitly in ground units or calculated based on the number of cells desired both horizontally and vertically.
Columns and rows are numbered and may start in any of the four corners of the features’ bounding box.
If the cell size is explicit, seed coordinates for x and/or y may be applied to adjust the grid’s position.
In this example, we have a set of transit lines, and want to create a variety of grids over the extents of the dataset.
Note that the features have a UTM coordinate system, with ground units in meters.
The features are routed into multiple 2DGridAccumulators.
Rectangular Grid
In the first parameters dialog, Grid Type is set to Cell Size, with size set to 1000 meters square. Type of Grid to Create is Polygons.
The resulting grid covers slightly more than the data extents - a result of the fixed cell size, starting from the lower left corner.
The polygons have received a new attribute containing their column and row numbers.
Grid Points
Dividing the extents into equal parts, Grid Type is set to Number of Cells and a 3 x 3 grid is requested.
Type of Grid to Create is Points (Corners).
Points are placed at the calculated cell corners.
Note that the Starting Corner was Lower Left, which becomes column 0, row 0. The grid does not extend past the features, as the cell size was calculated by dividing those extents into equal cells.
With Type of Grid to Create set to Points (Centers), each cell is represented by its center point. The Starting Corner cell (in this case, lower left) is column 0, row 0.
In this example, we will use seed values to refine the rectangular grid from the previous example, creating a grid that can be replicated and aligned with other generated grids.
Note that the grid cells are 1000 by 1000 meters, starting in the lower left corner.
As they are positioned relative to the extents of the underlying features, the cells would not necessarily line up with another 1000 by 1000 meter grid generated for a different feature set in the same area.
In the parameters dialog, we set both Seed Coordinate X and Y to 1000.
The resulting grid has cells placed predictably, falling every 1000 meters both horizontally and vertically.
Using the same seed values and cell size on another dataset produces a grid that aligns with this one.
Creating Boxes and Rectangles
Creating rectangular geometry is a common task. These transformers do so in a variety of ways.
Transformer |
Function |
Creates one or more new features with box geometry of a specific size and position (when Geometry Object is Box). |
Replaces an existing feature’s geometry with a box of a specific size and position. |
Creates one rectangle that encompasses all features received. |
Individually replaces the geometry of each feature with a rectangle that covers its extents. |
Individually replaces the geometry of each raster feature with a rectangle that covers its extents (with various Extents Type options). |
Extracts the coordinate values that describe an individual feature’s bounding box (or cube) and stores them as attributes. |
Creates a series of regularly-spaced rectangles that span the extent of all features received (when Type of Grid to Create is Polygons). |
Creates a series of regularly-spaced rectangles of a specific size and position (when Type of Grid to Create is Polygons). |
Tiler and RasterTiler |
Do not create actual rectangles, but chop features into a series of rectangular tiles, specified in a similar fashion to the 2DGridAccumulator. |
Features with geometry.
A grid of point or polygon features as specified in parameters.
Features without valid geometry are output via this port.
When using attribute values to define the grid, features with non-numeric values for any required numeric parameters are output through this port. However, once a feature with valid numeric values is received, all following features will use these same attribute values and will not be rejected.
INVALID_GEOMETRY_VERTICES
INVALID_PARAMETER_SEED_COORDINATE_X
INVALID_PARAMETER_SEED_COORDINATE_Y
INVALID_PARAMETER_HORIZONTAL_COUNT
INVALID_PARAMETER_VERTICAL_COUNT
INVALID_PARAMETER_COLUMN_WIDTH
INVALID_PARAMETER_ROW_HEIGHT
Group By |
The input features may be partitioned into groups based on attribute values. One grid is output for each group. If Group By is not specified, all input features will be processed together and a single grid will be output. |
Complete Groups
Grid Type |
Select a method for generating a grid.
Starting Corner |
Select the corner for the origin of the grid. Numbering starts at 0,0. When Grid Type is Cell Size, the last column and/or row may extend beyond the bounding box of the input features. The last column/row is opposite the selected Starting Corner. |
Type of Grid to Create |
Select the grid type:
Cell Size
When Grid Type is Cell Size:
If any of these values are supplied via an attribute or expression, the values used are taken from the first encountered feature of the group. Values from subsequent features are ignored. |
Number of Cells |
When Grid Type is Number of Cells:
Column |
Name the attribute to contain column numbers, relative to the Starting Corner. Numbering starts at 0. |
Row |
Name the attribute to contain row numbers, relative to the Starting Corner. Numbering starts at 0. |
Dialog Options - Tables
Yes |
Dependencies |
None |
Aliases |
2DGridReplacer |
History |
Search for all results about the 2DGridAccumulator on the FME Community.
