2DEllipseReplacer
Replaces or creates feature geometry with a 2D ellipse as defined in parameters for center point, radii, and rotation.
Creating ellipse or circle geometry from attribute values or user parameters
Replacing point geometry with ellipses or circles defined by values
The 2DEllipseReplacer receives features of any kind and replaces their geometry with ellipses as defined in parameters.
The parameters describe an ellipse as a closed Arc By Center Point by the following:
Center X and Y coordinates
Primary and Secondary Axis (radii) in ground units
Rotation in degrees
An assumed sweep of 360 degrees
Values may be entered or provided through attribute values, expressions, or user parameters.
If the feature has point or ellipse geometry, and Center X and Y are left blank, the coordinates of the feature’s existing geometry will be used. If the feature has no geometry or geometry other than point or ellipse, the feature is rejected.
For more information on ellipse geometry see Ellipse.
In this example, we have a set of points and want to replace them with ellipses of a fixed size and orientation.
The features are routed into a 2DEllipseReplacer.
In the parameters dialog, values are entered for Primary and Secondary Axis and Rotation, but the Center X and Y parameters are left blank.
The points have been replaced by ellipses as specified.
To create circles around point features, consider using a Bufferer.
If only one of Center X and Center Y is specified, then all features are output through the <Rejected> port.
If Center X and Center Y are blank, features with non-ellipse/point geometries are output here.
Features that receive non-numeric values for any numeric parameters are output via this port.
INVALID_PARAMETER_PRIMARY_RADIUS
INVALID_PARAMETER_SECONDARY_RADIUS
INVALID_PARAMETER_ROTATION
INVALID_PARAMETER_CENTER_POINT
Center X |
Specify the X coordinate of the ellipse’s origin. If blank, and the input feature is a point or ellipse, the X coordinate of that feature’s geometry will be used. If blank, and the input feature is not a point or ellipse, the feature is output via the <Rejected> port. |
Center Y |
Specify the Y coordinate of the ellipse’s origin. If blank, and the input feature is a point or ellipse, the Y coordinate of that feature’s geometry will be used. If blank, and the input feature is not a point or ellipse, the feature is output via the <Rejected> port. |
Primary Axis |
Specify the primary radius of the ellipse in ground units. Note that the primary radius need not be larger than the secondary, however, the rotation angle is always measured from the x axis to the primary axis. For a circle, set both the primary and secondary radius to the same value. |
Secondary Axis |
Specify the secondary radius of the ellipse in ground units. |
Rotation |
Specify the rotation in degrees of the primary axis from horizontal (if any). |
Dialog Options - Tables
Search for all results about the 2DEllipseReplacer on the FME Community.
