Oracle Non-Spatial Reader/Writer
                                                FME can read and write attribute data stored using Oracle. This module communicates directly with Oracle for maximum throughput.
Using FME with Oracle Formats
| Oracle Format | Data Type |
        Oracle Non-Spatial Reader/Writer  |
        attributes only  |
        raster  |
        object relational model (referred to as the object model)  |
        point cloud  |
        relational model  |
Oracle Non-Spatial Product and System Requirements
        Format  |
        FME Platform  |
        Operating System  |
        Reader/Writer  |
        FME Form  |
        FME Flow  |
        FME Flow Hosted  |
        Windows 64-bit  |
        Linux  |
        Mac  |
        Reader  |
        Yes  |
        Yes  |
        Yes  |
        Yes  |
        - Linux Intel: Yes - Linux ARM: Yes  |
        - macOS Intel: Yes - macOS ARM: No  |
        Writer  |
        Yes  |
        Yes  |
        Yes  |
        Yes  |
Format Notes
        Oracle and FME  |
        Description  |
| Oracle Instant Client |
        Instant Client can be used to run your OCI, OCCI, JDBC, and ODBC applications without installing a full Oracle Client. Instant Client supports SQL*Plus. See the FME Community for more information on how Instant Client works with FME.  |
| Oracle Wallet | To use an Oracle Wallet with FME, leave the Username and Password parameters empty, and enter the name of the Oracle Wallet as the value of the Service Name or Easy Connect parameter. |
Reader Overview
This reader reads non-spatial tables from Oracle Non-spatial databases.
Writer Overview
The Oracle Non-Spatial writer module stores attribute data in an Oracle database. The writer supports the following features:
        Feature  |
        Description  |
        Transaction Support  |
        Provides transaction support that eases the data loading process. Occasionally, a data load operation terminates prematurely due to data difficulties. The transaction support provides a mechanism for reloading corrected data without data loss or duplication.  |
        Table Creation  |
        Uses the information within the FME workspace to automatically create database tables as needed.  |
        Table Dropping  |
        Allows each table to be written to be dropped if recreating, or truncated if appending.  |
        Index Creation  |
        Sets up and populates all needed indexes and index tables as part of the loading process.  |
        Bulk Loading  |
        Uses a bulk loading technique to ensure speedy data load.  |
