Esri Geodatabase (XML Workspace Document) Quick Facts
                                                             Format Type Identifier  |
                                                             GEODATABASE_XML  |
                                                             Reader/Writer  |
                                                             Reader  |
                                                             Format is available only on:
                                                             Dependencies  |
                                                             ArcGIS 9+ The bit version (64-bit) must be the same for FME and ArcGIS.  |
                                                             Dataset Type  |
                                                             File  |
                                                             Feature Type  |
                                                             Table/Feature Class name  |
                                                             Typical File Extensions  |
                                                             .xml or .ZIP or .Z  |
                                                             Automated Translation Support  |
                                                             Yes  |
                                                             User-Defined Attributes  |
                                                             Yes  |
                                                             Coordinate System Support  |
                                                             Yes  |
                                                             Generic Color Support  |
                                                             No  |
                                                             Spatial Index  |
                                                             Always  |
                                                             Schema Required  |
                                                             No  |
                                                             Transaction Support  |
                                                             Not applicable  |
                                                             Geometry Type  |
                                                             geodb_type  |
                                                             Encoding Support  |
                                                             Yes  |
Esri Geodatabase (XML Workspace Document) Geometry Support
                                                             Geometry  |
                                                             Supported?  |
                                                             aggregate  |
                                                             yes  |
                                                             circles  |
                                                             yes  |
                                                             circular arc  |
                                                             yes  |
                                                             donut polygon  |
                                                             yes  |
                                                             elliptical arc  |
                                                             yes  |
                                                             ellipses  |
                                                             yes  |
                                                             line  |
                                                             yes  |
                                                             none  |
                                                             yes  |
                                                             point  |
                                                             yes  |
                                                             polygon  |
                                                             yes  |
                                                             raster  |
                                                             yes  |
                                                             solid  |
                                                             no  |
                                                             surface  |
                                                             yes  |
                                                             text  |
                                                             yes  |
                                                             z values  |
                                                             yes  |
