Esri Mobile Geodatabase Quick Facts
                                            Esri Geodatabase Geometry Support
                                                             Format Type Identifier  |
                                                             ESRI_MOBILE_GEODATABASE  |
                                                             Reader/Writer  |
                                                             Both  |
                                                             Operating System  |
                                                             Windows 64-bit  |
                                                             Dependencies  |
                                                             Esri ArcGIS Pro 2.7 or newer Note  FME and ArcGIS must both be running on 64-bit machines.
                                                             Dataset Type  |
                                                             File  |
                                                             Feature Type  |
                                                             Feature Class name  |
                                                             Typical File Extensions  |
                                                             .geodatabase  |
                                                             Automated Translation Support  |
                                                             Yes  |
                                                             User-Defined Attributes  |
                                                             Yes  |
                                                             Coordinate System Support  |
                                                             Yes  |
                                                             Generic Color Support  |
                                                             No  |
                                                             Appearance Support (Surfaces Only)  |
                                                             Yes  |
                                                             Spatial Index  |
                                                             Always  |
                                                             Schema Required  |
                                                             Yes  |
                                                             Transaction Support  |
                                                             Yes  |
                                                             Geometry Type  |
                                                             geodb_type  |
                                                             Encoding Support  |
                                                             Yes  |
