Garmin GDB Reader/Writer
                                            FME reads from and writes to the Garmin GDB format: a binary format that contains waypoints, tracks, and routes generated by a Garmin® GPS device.
Garmin GDB is used by Garmin MapSource software versions 6.0 and above. Garmin’s MPS file format was used prior to version 6.0.
Garmin GDB Product and System Requirements
                                                             Format  |
                                                             FME Platform  |
                                                             Operating System  |
                                                             Reader/Writer  |
                                                             FME Form  |
                                                             FME Flow  |
                                                             FME Flow Hosted  |
                                                             Windows 64-bit  |
                                                             Linux  |
                                                             Mac  |
                                                             Reader  |
                                                             Yes  |
                                                             Yes  |
                                                             No  |
                                                             Yes  |
                                                             Yes  |
                                                             Yes  |
                                                             Writer  |
                                                             Yes  |
                                                             Yes  |
                                                             No  |
                                                             Yes  |
                                                             Yes  |
                                                             Yes  |
Reader Overview
FME considers a single Garmin GDB file to be a dataset. All features in each dataset use the LL84 coordinate system.
Unicode attribute reading is supported.
Writer Overview
The dataset is the destination filename. The feature type of each dataset is the filename.
The Garmin GDB writer will only write data in decimal degrees (WGS84 datum). All features passed to the writer will be reprojected to LL84 (EPSG:4326) if this functionality is licensed. Features with no coordinate system are assumed to be in LL84.
The Garmin GDB writer uses a fixed schema.
For the Garmin GDB format, GPSBabel will always create an equivalent waypoint for every route point or route vertex written.
The order of route points and track points is important. Ensure that route points are sorted by route_fid and route_point_id, and track points are sorted by track_fid, track_seg_id, and track_seg_point_id. Unsorted points may yield unexpected results.
Garmin GDB does not support multi-segment tracks. Multiple segments will be joined into a single segment.
