Topic Monitoring
Select Automations > Notifications > Topic Monitoring.
Note
Topic monitoring is a backward compatible feature and is not required for Automations or Notifications to function.
If this feature does not behave as expected after Configuring for HTTPS, see the troubleshooting guide. Alternatively, monitor topics in automations with the FME Flow Topic trigger and Log a Message action.
The topic monitoring page provides a convenient place to monitor Notification Service activity on Topics without having to reference log files.
In the Topics to Monitor drop-down list, select the topics you want to monitor. To stop monitoring, click the Stop Monitoring icon. To restart monitoring, click the Start Monitoring icon.
Note Topic monitoring uses the WebSocket communication protocol, which occurs over port 7078. If necessary, be sure to configure any firewall settings to allow for open communication on port 7078.
Depending on how many topics you are monitoring, for how long, and the amount of activity on your server, this page may fill quickly with records. Use the Search field to limit the records that display. For example, to show only job failures, type "fail".
To clear all of the records and start over, click Clear Results.
