Manual Parameters Editor
The Manual Parameters Editor allows you to create output parameters that allow for different types of user input at workspace runtime.
In the editor dialog, the left pane lists all the existing manual parameters for the automation. You can use the toolbar icons to perform the following:
- Add a parameter: Click the Insert icon (+) and select the type of parameter you want to add (see Manual Parameter Types, below). The parameter is added below the currently-selected parameter . In the right pane, configure the properties of the parameter according to its type (see Parameter Properties (Right Pane), below).
- Edit a parameter: Click on one to select it. The parameter's properties display on the right pane.
- Change the order of the parameter at runtime.
- Remove a parameter.
When finished, click OK.
