Distributing FME Flow Components
You can distribute the components of an FME Flow installation to achieve an n-tier architecture. Both 2-tier and 3-tier configurations are supported:
Mouse-over for diagram:
In a 2-tier architecture, an Apache Tomcat web application server runs the FME Flow Web Services, and is installed alongside the the FME Flow Core and FME Engines. Only the FME Flow Database is installed separately, along with a remote file system for the FME Flow System Share.
Installing the web application server on the same host machine as the FME Flow Core is the recommended architecture for a distributed installation.
A 3-tier architecture separates the web application server to another host machine, splitting the presentation and application tiers.
In a 2- or 3-tier scenario, you can provide and manage the following components:
Note  Although the FME Flow Database and System Share will not have data redundancy by default, this can be set up by your organization.
Warning  We recommend installing the web application server on a system that is synchronized to the same time zone as the FME Flow Core. Differing time zones may result in improper timing of FME Flow Schedule triggers.
Recommended 2-tier Architecture
This diagram demonstrates the recommended 2-tier architecture, with the web application server, FME Flow Core, and FME Engines running on the same host, and separate servers for the FME Flow Database and FME Flow System Share. Optionally, you can add FME Engines on a Separate Machine.
Implementing a Distributed Architecture
Perform a distributed installation of FME Flow according to the 2-tier or 3-tier procedure:
Or, after an Express installation, perform the following reconfigurations, where necessary:
