Default User Accounts and Passwords
The FME Flow installer creates the following user accounts by default:
Note The default Status of these accounts, except the admin account, is Disabled.
Username/Password | Description | Default Status | Role |
admin/admin | Access to all FME Flow resources. Note You are prompted to update the admin password upon initial use, based on the default Password Policy configuration. |
Enabled | fmeadmin, fmesuperuser |
author/author | An account intended for FME Workbench authors. | Disabled | fmeauthor |
guest/guest | An account that provides the minimal access to FME Flow required to run workspaces. | Disabled | fmeguest |
user/user | An account intended for the FME Flow Web User Interface. | Disabled | fmeuser |
See Also
