Server Analytics
Use the Server Analytics page to view the Jobs load on your FME Server, within a specified time period, by queue, engine, or total job throughput. This information can help you balance when and how to run jobs, particularly through Schedules and Automations, so that FME Server operates more efficiently.
The large graph displays the number of jobs that were running during the specified period. (Only completed jobs are counted. Jobs that are still in a queued or running state are not counted). Mouse over a point on the graph to get exact job count and timestamp data for that interval.
Specifying Your Jobs Data
Use the Graph Data drop-down to specify the source data you want to view:
  • Job Throughput: View total job load data, regardless of queue or engine.
  • Queue Throughput: View job load data by queue. In the Queues drop-down, select up to five queues for which to view data.
  • Engine Throughput: View job load data by engine. In the Engines drop-down, select up to five engines for which you view data.
Specifying Time Period and Data Intervals
Use these controls, at top, to specify the time period you want jobs data to cover, and how to present it:
  • Select the chart time window: Specifies the time interval for presenting jobs data.
  • Start Date, End Date: Specifies the time window of jobs data.
You can click and drag inside the large graph to zoom in (shorten) the time interval. Doing so may adjust the time intervals along the bottom axis (for example, from days to hours, or from hours to minutes), and the job count intervals along the left axis.
Alternatively, the specified period also displays in the blue shaded area of the smaller graph at bottom. Grab and drag the handles on either side of this shaded area to adjust the time period further. Or, click and drag in the middle of the shaded area to move the entire time frame backward or forward.
