SAML Configuration
Select User Management > Authentication Services. On the Authentication Services page, select the SAML Configuration tab.
When enabled, you can incorporate users from your organization's Security Assertion Markup Language (SAML) identity provider for authentication with FME Server.
Note  Authentication with FME Server through SAML is not supported in the following FME Desktop transformers: FMEServerJobSubmitter, FMEServerNotifier, FMEServerResourceConnector, FMEServerJobWaiter, FMEServerLogFileRetriever.
Getting Started with SAML
To authenticate on FME Server with a SAML identity provider, you must configure settings in two places:
  • On FME Server.
  • On your SAML identity provider.
Viewing SAML Logs
Log files fmesaml.log and restV4.log can be found in Services Logs.
fmesaml.log records:
  • When a user account is created on initial login to FME Server through Sign in with SAML.
  • Subsequent logins to FME Server through Sign in with SAML.
restV4.log records any problems encountered during SAML configuration.
For more information, see About Log Files in FME Server.
