Deployment Parameter Store
Select System Configuration > Deployment Parameters.
The deployment parameter store provides a way to define and reuse common automation parameter values for Automations. Each deployment parameter you create becomes available as an attribute-value pair in a drop-down when you create an automations parameter. In conjunction with Projects, deployment parameters make it easier to port automations through the stages of enterprise development, from test to staging to production.
To Create a Deployment Parameter
Click New. In the Add Deployment Parameter dialog, complete the following fields, and click Add.
- Name: Provide a name for the automation parameter.
- Value: Provide a value for the automation parameter.
- Type: text
To Edit a Deployment Parameter
Click a deployment parameter to open it.
To Remove a Deployment Parameter
Select one or more deployment parameters, click Actions, and select Remove.
