Backing Up an FME Server Configuration
Tip  To perform regularly scheduled backups, see Performing Scheduled Backups of an FME Server Configuration.
  1. Select Backup & Restore > Backup. The Backup & Restore page opens on the Backup tab.
  2. Note  On earlier versions of FME Server, this page may be named "Migration," and the interface may not match exactly the description that follows.
  3. Filename: (Optional) Edit the name of the backup file.
  4. Backup To:
See Also
