FME Server Schedule
Use the Schedule trigger to complete workflow tasks at specific times in the future. You can use a Schedule trigger in conjunction with an Action, such as Run Workspace, or an External Action, such as Email.
The Schedule trigger has two output ports. The success port (✔) can send a message if the trigger initiates successfully. The failure port (x) can send a message if the trigger fails to initiate.
- Schedule Type: Specify how often the task repeats:
- Basic: Repeats based on a calendar-friendly selection of intervals derived from a specified Start time.
- Repeat On Interval: Repeats in intervals from a list of predefined units.
- CRON Expression: Repeats based on your own cron expression.
- Date Range: Specify the schedule Start and/or End times. Alternatively, select Start Immediately and/or Does Not Expire, respectively.
- Recurrence: If Schedule Type is Basic, specify how often the task repeats from the drop-down selections.
If Repeat on Interval is specified, the schedule does not adjust when switching between Standard Time and Daylight Saving Time.
| Field | Required | Allowed Values | Allowed Special Characters |
| Seconds | Yes | 0-59 | , - * / |
| Minutes | Yes | 0-59 | , - * / |
| Hours | Yes | 0-23 | , - * / |
| Day of month | Yes | 1-31 | , - * ? / L W |
| Month | Yes | 1-12 or JAN-DEC | , - * / |
| Day of week | Yes | 1-7 or SUN-SAT | , - * ? / L # |
| Year | No | empty, 1970-2099 | , - * / |
For more information about the cron format, see this FME Community article.
Output Attributes
See Also
| Attribute | Description |
| time | Event time |
| source | Event type |
| error.type |
(Failure port only) Error type:
| error.message | (Failure port only) Error message |
Testing a Schedule-Initiated Worfklow
For testing purposes, you can force a workflow that is initiated by a Schedule trigger to run at any time, regardless of the specified parameters of the Schedule.
When ready to test your FME Server Schedule workflow:
- Click Start Automation to enable the workflow.
- Double-click on the Schedule component you want to initiate the worfklow.
- Under Schedule Details, click Trigger.
A Trigger Schedule message displays to indicate whether the Schedule trigger was successfully requested. If so, the workflow runs as it is currently configured.
