Email - IMAP
The Email - IMAP trigger receives email messages from an IMAP server.
The Email - IMAP trigger has two output ports. The success port () can send a message if the trigger fetches successfully. The failure port (x) can send a message if the trigger fails to fetch.
Warning  When the Email - IMAP trigger polls the IMAP server, every unread email in the in-box is marked as read.
Note  IMAP access must be enabled on the email account that is polled for messages.
Output Attributes
