SMTP Publisher
The SMTP email publisher allows you to configure email addresses to receive messages from SMTP email clients, and publish the email data to FME Server notification topics.
To use the email publisher, you must first make sure your FME Server is properly configured to receive email. For more information see Configuring FME Server to Receive Email.
Note  The SMTP Publisher is not supported in a fault tolerant installation of FME Server. Consider the IMAP Publisher instead.
In this section:
