Starting and Stopping FME Server
After performing the installation, the FME Server service and associated applications start automatically. You might have to start and stop these applications at some point. See Starting and Stopping FME Server Manually for instructions.
Note  If UAC (User Account Control) is enabled on your Windows system and the installation was not run from an elevated prompt (that is, Run as administrator), you might need to start the FME Server Windows Services.
What's Next?
