RasterObjectDetectionModelTrainer
Trains a custom raster object detection model based on the positive and negative samples.
Trains a custom raster object detection model based on the positive and negative datasets. The resulting model file can be used to detect the desired object using RasterObjectDetector. For convenience, you may get the input datasets from RasterObjectDetectorSamplePreparer that takes multiple positive samples and a number of negative samples for preparation. Or you may generate artificial samples using RasterObjectDetectorSampleGenerator (note that artificially generated samples usually perform worse than hand-picked ones)
Note that the transformer calls an external (opencv_traincascade) process to perform the model training. At the moment, if translation is suspended or stopped, the opencv_traincascade process is going to remain running and will need to be killed manually.
Dialog Options - Tables
Search for all results about the RasterObjectDetectionModelTrainer on the FME Community.
