PointPropertyExtractor
Extracts point orientation to feature attributes.
Features with point geometries.
Features with newly set attributes based on point orientation. No attributes are added to features containing points with no orientation.
Note: Feature order may change in relation to other output ports. Feature order per port is maintained.
Orientation Mode |
Specifies the representation to use when extracting point orientation. The following representations are supported:
| 2D Rotation |
Name the attribute to contain the 2D rotation. |
| Orientation Normal X | Name the attribute to contain the X component of the normal. |
| Orientation Normal Y | Name the attribute to contain the Y component of the normal. |
| Orientation Normal Z | Name the attribute to contain the Z component of the normal. |
| Spin | Name the attribute to contain the spin. |
| Axis Angle X | Name the attribute to contain the X component of the axis. |
| Axis Angle Y | Name the attribute to contain the Y component of the axis. |
| Axis Angle Z | Name the attribute to contain the Z component of the axis. |
| Rotation | Name the attribute to contain the degrees of rotation around the axis (right hand rule). |
| Azimuth | Name the attribute to contain azimuth. |
| Altitude | Name the attribute to contain altitude. |
| Coefficient A to I |
Name the attributes to contain the coefficients of the transformation matrix: x' = Ax + By + Cz y' = Dx + Ey + Fz z' = Gx + Hy + Iz |
| X | Name the attribute to contain the x coefficient. |
| Y | Name the attribute to contain the y coefficient. |
| Z | Name the attribute to contain the z coefficient. |
| W | Name the attribute to contain the w coefficient. |
| A | Name the attribute to contain the first rotation, around the Z-axis. |
| B | Name the attribute to contain the second rotation, around the X’-axis. |
| Y | Name the attribute to contain the third rotation, around the Z’’-axis. |
| Yaw | Name the attribute to contain yaw. |
| Pitch | Name the attribute to contain pitch. |
| Roll | Name the attribute to contain roll. |
Dialog Options - Tables
Search for all results about the PointPropertyExtractor on the FME Community.
