MultipleGeometrySetter
Provides the ability to set up an aggregate where each part is independent from the others, and its own complete geometry.
For example, if an aggregate enters and it contains two parts, a line and a polygon, it will leave containing the same two parts, but the difference will be that each part should now be interpreted as its own separate geometry. For example, a database writer that supports this concept may then write out each of the multiple geometries to its own geometry column.
About Multiple Geometry
Dialog Options - Tables
Transformer History
This transformer was previously named IndividualGeometriesSetter.
Search for all results about the MultipleGeometrySetter on the FME Community.
Keywords: aggregate individual multiple many "multiple geometry" multigeometry IndividualGeometriesSetter
