MinimumSpanningCircleReplacer
Replaces the geometry of the feature with a polygon representing its minimum spanning circle. The minimum spanning circle is defined as the smallest circle that encloses all vertices of the passed-in feature.
Mode |
In Replace Geometry mode, each feature's geometry will be replaced with the calculated circle. In Set Attributes mode, the input geometry will be left untouched and the properties (location and radius) of the circle saved as the designated attributes on the feature. |
| Center X | Name the attribute to contain the x value of the circle center. |
| Center Y | Name the attribute to contain the y value of the circle center. |
Radius |
Name the attribute to contain the radius of the circle. |
Dialog Options - Tables
Search for all results about the MinimumSpanningCircleReplacer on the FME Community.
