LabelPointReplacer
Replaces the geometry of the feature with a label point.
The insertion point of the text is guaranteed to be inside (in case of polygons) or on (lines and points) the original object. Note that since the text itself may be larger than an input area feature, the bounds of the label may exceed the bounds of the area.
- If the feature was already a point, it is simply turned into a text feature at the original location.
- If the feature was a line, it is turned into a point text feature at the midpoint of the line, with a rotation parallel to the line.
- If the feature was an area feature, the resulting point is somewhere in the interior of the feature (and outside of any holes in the area).
Example
Input features must have the correct geometry: point, line or area.
The features with the replaced geometry are output via this port.
Invalid features are output via this port.
Rejected features will have an fme_rejection_code attribute with one of the following values: EXTRA_FEATURE, INVALID_GEOMETRY_TYPE, INVALID_GEOMETRY_VERTICES.
Label |
The label to add to the geometry. |
Label Height |
The label height is measured in ground units, and may either be entered as a number, or can be taken from the value of a feature attribute by selecting the attribute name from the pull-down list. |
Always Rotate Label |
The label is rotated to prevent it from appearing upside down. |
Dialog Options - Tables
To generate a point that will be used as a centroid for polygons, use an CenterPointReplacer. This saves you the overhead of having a text object.
Search for all results about the LabelPointReplacer on the FME Community.
Keywords: LabelPointCreator TextReplacer
