EnvironmentVariableFetcher
Fetches the specified environment variable and includes it in a new attribute.
Environment variables are convenient especially if certain standard folders and parameters need to be referenced in a workspace, but the actual locations or names can vary from computer to computer.
The available variables will depend on which platform you are using.
Within an FME workspace you could use the value retrieved to:
- Define the output location of a dataset (in conjunction with Feature Type Fanout, which is described in the FME Workbench help files)
- Define the location of a file for the AttributeFileWriter or AttributeFileReader
- Define the location of a workspace to run with the WorkspaceRunner
- Write the value to some type of metadata output
Environment Variable |
Type the environment variable name (for example, PATH or TEMP). |
| Fetched Value | Name the attribute to contain the value. |
Dialog Options - Tables
Transformer History
This transformer has been renamed from EnvironmentVariableRetriever.
Search for all results about the EnvironmentVariableFetcher on the FME Community.
Keywords: EnvironmentVariableRetriever
