CityEngineModelGenerator
Generates 3D models from input geometries and ArcGIS CityEngine rule packages (*.rpk).
- Read in a geometry file of a building footprint with an FME Reader and pass the generated Feature to a CityEngineModelGenerator transformer to output 3D geometry in FME.
- Analyze an input .rpk file and generate a config JSON attribute of the CGA attributes defined in the .rpk file which can be used to customize the model generation process.
The CityEngineModelGenerator uses CityEngine to apply rule packages to input geometry to produce textured 3D models. The input geometry is provided as FME geometry on the input feature. The generated model is output as 3D geometry on the feature.
Note: This transformer uses PyPRT, which is a Python Binding for the CityEngine SDK.
Legal Disclaimer: It is free for non-commercial use, however, commercial use requires at least one commercial license of the latest Esri CityEngine version installed in the organization.
See PyPRT for further details.
Use the “Generate Model” action to apply an extrusion .rpk file to a building footprint provided as FME input geometry read in using an FME Reader.
Use the “Generate Configuration Template” action to generate a config JSON template attribute of the CGA attributes defined in an extrusion .rpk file. Edit the JSON attribute to change the building color and building height. In another CityEngineModelGenerator, use the “Generate Model” action to apply the JSON attribute and .rpk on input footprint geometry.
- The rule package file can contain CGA attributes which can be specified for model generation. To edit these attributes for model generation, run the transformer with ‘Action’ as ‘Generate Configuration Template’ to generate a config JSON as an FME attribute which can be edited to insert these values.
When editing the configuration JSON string of CGA attributes, the data type (such as float, int, string) is STRICT. The attribute values inserted into the JSON must be of that data type for the CGA attribute value to be applied to the resulting geometry output. The transformer will attempt to convert the value to the correct data type but it is recommended that you input the CGA attribute with the correct data type to avoid unexpected results.
For example below:
For example, “input”: null should have the value "input": 30.0 to be applied correctly because of the “type: float”.
"input": 30 is incorrect and will be converted into a float at runtime and trigger a warning.
The specified input must be within the “range” of 28 and 150.
Example Output:
"BuildingHeight" : {
"input" : null,
"range" : [28, 150],
"type" : "float",
- The specifications of the CGA attribute values are defined individually in each rule package. It is important to understand the rule package you are using.
For example:- There could be a rule package that has a color attribute buildingColor that specifically requires a hex color string. The configuration JSON string will define the type as "string", but "buildingColor": {“input” : "blue" } is not valid, whereas "buildingColor": { “input”: "#0000FF" } is valid.
CityEngine stores geometry internally in a y-Up orientation, which does not match the standard z-Up orientation of FME and other GIS applications. As a result, the CityEngineModelGenerator will transform input geometry from an assumed z-Up orientation to y-Up before processing through the PyPRT module. The generated geometry model will be transformed to a z-Up orientation on output.
The input geometry is expected to be in a projected coordinate system. Any input Feature in a geographic coordinate system will be rejected by the transformer and will need to be reprojected to a projected coordinate system beforehand.
- Caution: When using an expensive rpk file that applies lots of textures to the models, the FME Data Inspector can take a significant amount of time to load the rasters.
Geometry taken as input to the transformer should have non-zero total area. Input Feature cannot be in a geographic coordinate system.
For the Generate Model action - the original FME Feature with the geometry set to the generated models (FME Mesh or Aggregate).
For the Generate Configuration Template action - the original FME Feature with a CGA attribute template JSON string attribute.
Attributes
| _file_base_name | The specified base file name for all generated files. |
| _output_destination | The destination where the model and files are generated. |
The incoming feature is output through this port.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute describing the category of the error will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure. Rejection codes include:
INVALID_PARAMETER - An input parameter is unrecognized.
CITY_ENGINE_MODEL_GENERATOR_ERROR - General error that will be explained in the fme_rejection_message.
PYPRT_ERROR - The ESRI 3rd party dependency PyPRT generated an error.
INVALID_GEOMETRY_ERROR - The geometry on the input feature is unsupported.
OUTDATED_TRANSFORMER - The transformer needs to be upgraded before proceeding.
MISSING_LEGAL_USER_AGREEMENT - The legal terms need to be reviewed and agree before proceeding.
UNRECOGNIZED_OUTPUT_FILE_TYPE - The specified output file type is not recognized or supported.
UNRECOGNIZED_INPUT_FILE_TYPE - The specified input file is not recognized or supported.
| Action |
Select the mode for the transformer to take:
The remaining parameters available depend on the value of the Action parameter. Parameters for each Action are detailed below.
Input
Rule Package |
The file path to the rule package (*.rpk) file |
Output
Configuration JSON Attribute |
The attribute name to write the generated CGA JSON configuration to.
Default is _cga_attr_json Example output: Copy input: the value you would like to specify range: the range of possible values that can be accepted as input type: the value type accept as input (strict) |
Input
Method |
The output method of Feature or File.
File |
Specify the location of the 2D geometry file. Supported file types include:
Rule Package |
Configuration JSON |
Specify the CGA JSON configuration attribute name. If not specified, no user-defined CGA attributes will be applied to the model generation process and all defaults defined by the .rpk file will be used. On input, only the attribute’s “input” key is required. Example Input: Copy
Output
Method |
File Type |
Select a file type to output 3D geometry to. Supported types include:
File Base Name |
Specify a base file name for all generated files. |
Destination |
Specify a destination where the output 3D geometry and assets are output to. |
CGA Report |
The attribute name for the generated CGA report. Default is _cga_report |
CGA Print |
The attribute name for the generated CGA print. Default is _cga_print |
Dialog Options - Tables
| Dependencies | Esri ArcGIS CityEngine Commercial license for commercial use |
Operating System Restrictions |
Windows 64-bit only |
Search for all results about the CityEngineModelGenerator on the FME Community.
