CharacterCodeExtractor
Extracts the character code of the first character in the input string attribute, and adds its integer value in the character set to the feature as another attribute.
This can be used to obtain the integer code of any character from a list of supported encodings, including non-printable ones.
Example
For example, a CJK unified ideograph 东 character as the first character of the input string attribute and an input string encoding type of Unicode 8-bit(utf-8), would result in a value of 19996 (U+4E1C) being placed in the character code attribute.
Input String Attribute |
The attribute that contains the character for which you would like to find the equivalent numeric code |
| Input String Encoding | Select the encoding of the input string. |
| Character Code | Name the attribute to contain the resulting code. |
Dialog Options - Tables
Search for all results about the CharacterCodeExtractor on the FME Community.
