2DBoxReplacer
Replaces the geometry of the feature with a two-dimensional box whose minima and maxima are fixed values, or are taken from attributes in the original feature.
The dynamic <Rejected> port appears when a parameter is set to a non-literal value that might make processing impossible.
For example, if a numeric parameter such as Line Width, Count Start, or Decimal Places is set to an expression, attribute value, or user parameter, it is possible to pass in a non-numeric value that cannot be used. Decimal Places = Cat cannot be processed, so the feature will be output via this port.
Rejected features will have an fme_rejection_code attribute explaining the reason for rejection.
General
The minimum X value. You can enter parameters as a number, or choose them from the value of a feature attribute by selecting the attribute name from the pull-down list.
The minimum Y value. You can enter parameters as a number, or choose them from the value of a feature attribute by selecting the attribute name from the pull-down list.
The maximum X value. You can enter parameters as a number, or choose them from the value of a feature attribute by selecting the attribute name from the pull-down list.
The maximum Y value. You can enter parameters as a number, or choose them from the value of a feature attribute by selecting the attribute name from the pull-down list.
To replace a feature with its bounding box in one step, use the BoundingBoxReplacer.
To retrieve the bounds of a feature into attributes, use the BoundsExtractor.
Dialog Options - Tables
Search for all results about the 2DBoxReplacer on the FME Community.
