2DArcReplacer
Replaces the geometry of the feature with a two-dimensional arc whose shape is set by the parameters, which can be either constant floating point values or the values of existing attributes.
Example
  • If the parameters for the arc are not known and need to be calculated from a linear feature’s geometry, use the ArcEstimator.
Dialog Options - Tables
Search for all results about the 2DArcReplacer on the FME Community.
