FME Server Parameters
FME Server parameters reference FME Server system settings when a workspace is run from FME Server. These parameters may be useful when testing or debugging a workspace that is going to be run from FME Server.
Parameter Description
FME_DATA_REPOSITORY Name of the folder used by FME Server for temporarily uploading data.
FME_ENGINE Name of the FME Engine that runs the workspace.
FME_JOB_ID FME Server job identifier of the job that invokes the workspace.
FME_SECURITY_ROLES Role of the FME Server user who runs the workspace. For example, fmeadmin and fmeauthor are two common roles.
FME_SECURITY_USER FME Server user that runs the workspace.
FME_SERVER_DEST_DIR File path where the FME Server Data Download and Data Streaming services write output data.
FME_SERVER_HOST FME Server host name used to invoke this workspace.
FME_SERVER_PORT FME Server port on which the workspace is invoked.
FME_SERVER_REQUEST_HEADERS FME Server Web Services request header information, which includes the client IP of requests used to invoke the workspace.
FME_SERVER_REQUEST_METHOD HTTP request method used to invoke the workspace. This parameter is set only in workspaces that are run by the FME Server Data Streaming service.
FME_SERVER_REQUEST_PARAMETERS FME Server Web Services request query parameters. Includes query parameters passed as part of the URL, as well as query parameters sent through a POST request body of content type "application/x-www-form-urlencoded" and "multipart/form-data".
FME_SERVER_REQUEST_URI FME Server Web Services URI used to invoke the workspace. This parameter is set only in workspaces that are run by the FME Server Job Submitter, Data Streaming, or Data Download services.
FME_SERVER_RUNTIME_USER User name of the FME Server account that authenticated with the FME Server workspace app to run the workspace.
FME_SERVER_RUNTIME_USER_ID Unique identifier of the FME Server user account that authenticated with the FME Server workspace app to run the workspace.
FME_SERVER_WEB_URL Web Application Server root URL that invokes the workspace.
FME_SHAREDRESOURCE_BACKUP FME Server Resources folder for storing FME Server backup files.
FME_SHAREDRESOURCE_DASHBOARD FME Server Resources folder for storing Dashboard reports.
FME_SHAREDRESOURCE_DATA FME Server Resources folder for storing data files that can be shared between workspaces.
FME_SHAREDRESOURCE_ENGINE FME Server Resources folder for storing FME Engine resources.
FME_SHAREDRESOURCE_LOG FME Server Resources folder for storing log files.
FME_SHAREDRESOURCE_SYSTEM FME Server Resources folder for storing connections to network resources.
FME_SHAREDRESOURCE_TEMP FME Server Resources folder for storing temporary files created by FME Server.
FME_TOPIC_MESSAGE Location of the FME  Server Notification Service message. This parameter is set only in workspaces that are run from an FME workspace subscriber. For more information, see FME workspace Subscriber in the FME Server documentation.
FME_TOPIC FME Server Notification Service topic that invokes the workspace.
See Also
