VRT Raster (GDAL Virtual Format) Quick Facts
Format Type Identifier VRT_RASTER
Reader/Writer Reader
Licensing Level Professional
Dependencies None
Dataset Type File
Feature Type Varies: schema is dependent on the source dataset
Typical File Extensions .vrt
Automated Translation Support Yes
User-Defined Attributes Yes
Coordinate System Support Yes, see Coordinate Systems
Generic Color Support No
Spatial Index No
Schema Required No
Transaction Support No
Geometry Type vrt_raster
VRT Raster (GDAL Virtual Format) Geometry Support
Geometry Supported?
aggregate no
circles no
circular arc no
donut polygon no
elliptical arc no
ellipses no
line no
none no
point no
polygon no
raster yes
solid no
surface no
text no
z values yes
VRT Raster (GDAL Virtual Format) Support
Band Interpretations
Red8, Red16, Green8, Green16, Blue8, Blue16, Alpha8, Alpha16, Gray8, Gray16, Int8, UInt8, Int16, UInt16, Int32, UInt32, Real32, Real64
Palette Key Interpretations
UInt8, UInt16, UInt32
Palette Value Interpretations
RGBA32
Nodata Value
Specified per-source in the .vrt file
Cell Origin (x, y)
0.5, 0.5
Rotation Support
No
GCP Support
Yes
World File Support
No
TAB File Support
No (however, underlying formats may support it)
