Snowflake Spatial Reader/Writer
The Snowflake Spatial reader and writer modules provide FME with access to attribute data held in Snowflake database tables.
FME provides read and write access via Snowflake’s JDBC driver, which is bundled with FME.
Using Snowflake Spatial in FME
Spatial support for Snowflake is available in FME 2020.1 and up.
To learn more about Snowflake and FME, see:
- Using Geospatial Data in Snowflake
- FME Community: Using Snowflake Spatial in FME for Geospatial Data
Snowflake Spatial Product and System Requirements
Format |
Platform |
Operating System |
Reader/Writer |
FME Desktop License |
FME Server |
FME Cloud |
Windows 64-bit |
Linux |
Mac |
Reader |
Available in FME Professional Edition and higher |
Yes |
Yes |
Yes |
Yes |
Yes |
Writer |
Available in FME Database Edition and higher |
Yes |
Yes |
Yes |
Yes |
Yes |
The performance of this format is dependent on the amount of memory allocated to the Java Virtual Machine (JVM). The following environment variables allow you to specify memory available to Java Plugins:
FME_JVM_MIN_HEAP_SIZE
Initial heap size for initializing the JVM. If unset, the default value is 1024K.
This variable must be set in multiples of 1024 and greater than 1 MB. To indicate kilobytes, megabytes, or gigabytes, append k or K, m or M, or g or G, respectively. For example, any of these values is acceptable:
6291456
6144k
6m
FME_JVM_MAX_HEAP_SIZE
Maximum heap size for initializing the JVM. If unset, the default value is 16384K.
This variable must be set in multiples of 1024 and greater than 2 MB. To indicate kilobytes, megabytes, or gigabytes, append k or K, m or M, or g or G, respectively. For example, any of these values is acceptable:
83886080
81920k
80m
Note: To pass additional parameters used by FME to the Java Virtual Machine, use the JAVA_TOOL_OPTIONS environment variable.
