Specifying the FME Edition to Use
If your floating license service supports multiple editions of FME, you can use the flexlm_config.dat file to tell FME what edition to use.
To determine the FME editions you are licensed for, consult the safe.lic file on your license server.
To specify the FME Edition to Use
On the computer that is running FME Desktop, edit (or create) flexlm_config.dat in the C:\ProgramData\Safe Software\FME\Licenses folder.
The contents should be the following two lines:
Registered Product=<FME edition name>
<Displayed name in FME>
Example
Registered Product=smallworld
FME Desktop Smallworld Edition
<FME edition name> is case-sensitive. <Displayed name in FME> appears when you navigate to Help > About in FME Workbench or FME Data Inspector.
Possible values for FME Edition Name are:
| FME Edition Name | Displayed Name in FME |
| professional | FME Desktop Professional Edition |
| esri | FME Desktop Esri Edition |
| database | FME Desktop Database Edition |
| smallworld | FME Desktop Smallworld Edition |
