Downloading from FME Server
in the FME Workbench toolbar. The Download from FME Server wizard opens. Proceed through the panels of the wizard:
Note: To download from FME Server, you must have an FME Server configured and available. For more information, contact your System Administrator.
Tip: If you open the Translation Log, you can view connection and processing statistics while connected to FME Server.
