Tiler
Chops all input features into a series of tiles, covering the extent of all features.
Tile size may be specified in ground units or calculated from a specified number of columns and rows to cover the extent of all features. Tiles are numbered relative to the chosen starting corner.
When Define Tiles By is Dimensions in Ground Units, tile dimensions are specified in ground units. Features in a latitude/longitude coordinate system may need to be reprojected prior to tiling.
Features that span multiple tiles will be clipped into multiple features.
This transformer works with raster, vector and point cloud data.
Note: If you are inputting raster data, you may want to use the RasterTiler instead. The following table compares the Tiler and the RasterTiler:
Tiler | RasterTiler | |
Tiling extents |
Cumulative over all features |
Single feature |
Type of data accepted |
All types except surfaces and solids |
Raster only |
Tile size units |
Ground coordinates |
Pixel coordinates |
Tile row numbering (0, 1,...) |
Selectable |
Top to bottom |
Supports forcing equal-size tiles |
Yes |
Supports raster index attribute |
Yes |
Supports number of horizontal/vertical tiles attribute |
Yes |
Example
For temporary reprojection of geographic data for defined tile size, the CommonLocalReprojector may be useful.
This transformer tiles the input features - it does not create a new grid. To create a grid (points or polygons) over the extent of your features, use a 2DGridAccumulator. To generate a grid independent of other features, consider the 2DGridCreator.
The features that will be tiled. Point, curve, area, raster, and point cloud geometries are supported.
The tiled port contains all the features that have been successfully tiled.
The remnant port has any geometries that were unused during tiling.
The rejected port holds features that were invalid in a way that prevented tiling. For example, a geometry that spans to infinity in a direction.
The Invalid Parts Handling parameter determines what is output through the port. If Reject Parts Only is selected then only the parts that caused the feature to be invalid will be output through the rejected port. Otherwise, if Reject Whole Feature is selected the entire feature will be output through the rejected port.
Rejection codes include:
INVALID_PARAMETER_TILE_WIDTH
INVALID_PARAMETER_TILE_HEIGHT
INVALID_PARAMETER_SEED_COORDINATE_X
INVALID_PARAMETER_SEED_COORDINATE_Y
INVALID_PARAMETER_NUMBER_OF_HORIZONTAL_TILES
INVALID_PARAMETER_NUMBER_OF_VERTICAL_TILES
INVALID_GEOMETRY_NON_SPATIAL
INVALID_GEOMETRY_NOT_FINITE
Group By |
If Group By attributes are selected, features with the same values in the Group By attributes are placed into the same set, and clipping occurs in each set independent of other sets. |
Complete Groups |
![]() There are two typical reasons for using When Group Changes (Advanced) . The first is incoming data that is intended to be processed in groups (and is already so ordered). In this case, the structure dictates Group By usage - not performance considerations. The second possible reason is potential performance gains. Performance gains are most likely when the data is already sorted (or read using a SQL ORDER BY statement) since less work is required of FME. If the data needs ordering, it can be sorted in the workspace (though the added processing overhead may negate any gains). Sorting becomes more difficult according to the number of data streams. Multiple streams of data could be almost impossible to sort into the correct order, since all features matching a Group By value need to arrive before any features (of any feature type or dataset) belonging to the next group. In this case, using Group By with When All Features Received may be the equivalent and simpler approach. Note: Multiple feature types and features from multiple datasets will not generally naturally occur in the correct order. As with many scenarios, testing different approaches in your workspace with your data is the only definitive way to identify performance gains. |
Define Tiles By |
Dimensions in Ground Units: This option enables the Width(X) and Height(Y) parameters, which allow you to specify the width and height of each tile in ground units. Number of Tiles: This option enables the Columns and Rows parameters, which allow you to specify the number of tiles that will be produced. |
Starting Corner |
Chooses a starting corner for the purposes of numbering rows and columns. Also, when Define Tiles By is Dimensions in Ground Units, the last row and/or the last column may extend beyond the bounds of the input features; here the “last” row or column is the one opposite the Starting Corner. |
Dimensions in Ground Units |
Width(X)/Height(Y) These parameters are required when the Define Tiles By is Dimensions in Ground Units, and allow you to specify the size of each tile in ground units (for example, 100m x 100m). Note: If the source is a raster, does not have a coordinate system and is not georeferenced, then the raster extents and spacing are adjusted to default values. The horizontal and vertical spacing are set to one column and one row, respectively, and the origin is set to (0,0). Note: IMPORTANT: If attributes are used for the Width(X) or Height(Y) parameters, the value will be taken from the first feature per group. Seed Coordinate X/Y These optional parameters specify a "seed point" from which tiles will be generated. If the seed point is within the bounding box of all inputs to the group, the seed point will be the corner of a tile. Each coordinate is an optional parameter meaning we can specify a seed coordinate for only X, only Y, both or neither. If neither is specified then the seed point is the Starting Corner. Note: If attributes are used for the Seed Coordinate X or Seed Coordinate Y parameters, the value will be taken from the first feature per group. |
Number of Tiles |
Columns/Rows These parameters are required when the Define Tiles By is Number of Tiles, and allow you to specify how to tile the input data (for example, 5 horizontal tiles and 5 vertical tiles). Note: If attributes are used for the Columns or Rows parameters, the value will be taken from the first feature per group. |
Tolerance |
The minimum distance between geometries in 2D before they are considered equal, in ground units. If the tolerance is Automatic, a tolerance will be automatically computed based on the location of the input geometries. Additionally, a custom tolerance may be used. |
Duplicate Elements on Tile Borders |
This parameter allows elements along the border of more than one tile to be duplicated and added to each tile that they touch. |
Missing Z Values |
This parameter specifies how to deal with areas that have z values, but are missing at least one value after tiling.
In any mode, if no value is given for the z values, the output will be 2D. |
Missing Measure Values |
This parameter specifies how to deal with geometries that have some measures, but are missing at least one value after tiling.
If no value is given for a measure, the measure will be removed. |
Invalid Parts Handling |
This parameter specifies how to handle invalid parts. If Reject Parts Only is selected then only the parts that caused the feature to be invalid will be output through the rejected port. Otherwise, if Reject Whole Feature is selected the entire feature will be output through the rejected port. |
Preserve Feature Order |
Column |
Name the attribute to contain column numbers, relative to the Starting Corner. Numbering starts with 0. |
Row |
Name the attribute to contain row numbers, relative to the Starting Corner. Numbering starts with 0. |
Dialog Options - Tables
Search for all results about the Tiler on the FME Community.
Keywords: raster grid clip subset tile extent bound limit Tessellate Tessellation pointcloud
