SpikeRemover
Cleans up feature geometries by removing spikes.
The transformer looks at every pair of line segments made up of three consecutive distinct points. If the angle (in degrees) between two line segments is less than or equal to the specified maximum angle, then the middle point is a spike and is removed.
If the geometry of a feature is a path, the transformer removes spikes between consecutive path segments as well. For a polygon or donut, if the start/end point is a spike, then it is also removed. The end result is still a polygon/donut. Any polygons, donuts, paths or lines that are part of a collection of geometry will also be processed.
The transformer will also remove any consecutive duplicate points.
The transformer is not effective when the line contains many deviations other than spikes. In such cases, it is recommended to first clean up the features using the Generalizer transformer with Douglas-Peucker algorithm.
Example
Dialog Options - Tables
FME Community
The FME Community is the place for demos, how-tos, articles, FAQs, and more. Get answers to your questions, learn from other users, and suggest, vote, and comment on new features.
Search for all results about the SpikeRemover on the FME Community.
