PathSplitter
Decomposes a path feature into its component segments.
Each output feature will contain a copy of the source feature's attributes. Non-path input features will be output untouched.
Segment Number |
If specified, each output feature is given an attribute containing the part's segment index within the original path feature. |
Segment List |
The optional List Attribute is used to associate attributes with each segment of the path. If the feature has a list of attributes that are in parallel to the members of the aggregate, these can be decomposed onto the output features by specifying this parameter. |
Dialog Options - Tables
Search for all results about the PathSplitter on the FME Community.
