NeighborhoodAggregator
Creates aggregates of features based on their proximity to each other. Each aggregate that is created covers approximately the neighborhood width and height (measured in feature ground units).
This transformer is used to reduce the data volume of "wallpaper" types of features that have no individual attributes. The resulting aggregates can be output to a system using many fewer records than if each feature was output by itself. For systems that support aggregates, or multi-part features, this can result in substantial performance improvements and greatly decrease storage requirements.
Example
Group By |
If you do not select Group By attributes, then all features fall into the same group. When you select Group By attributes, this transformer will aggregate the geometries of the input features, based on the selection in the Group By parameter. Each group of features that have the same values for the Group By attributes will be processed independently of other groups. |
Complete Groups |
![]() There are two typical reasons for using When Group Changes (Advanced) . The first is incoming data that is intended to be processed in groups (and is already so ordered). In this case, the structure dictates Group By usage - not performance considerations. The second possible reason is potential performance gains. Performance gains are most likely when the data is already sorted (or read using a SQL ORDER BY statement) since less work is required of FME. If the data needs ordering, it can be sorted in the workspace (though the added processing overhead may negate any gains). Sorting becomes more difficult according to the number of data streams. Multiple streams of data could be almost impossible to sort into the correct order, since all features matching a Group By value need to arrive before any features (of any feature type or dataset) belonging to the next group. In this case, using Group By with When All Features Received may be the equivalent and simpler approach. Note: Multiple feature types and features from multiple datasets will not generally naturally occur in the correct order. As with many scenarios, testing different approaches in your workspace with your data is the only definitive way to identify performance gains. |
Neighborhood Width and Neighborhood Height |
These parameters, measured in ground units, divide the input space into cells. The result is a grid of cells that expands in all directions from the origin (0,0). The center of the bounding box of each input feature is used to determine the cell for the feature. Once all input features have been read, an aggregate feature is created from all features in each cell. If linear features are input, they will have pseudo nodes removed from within their cells to further reduce the number of separate entities. No such reduction is done to any polygons or donuts that enter. Note: To view the grid of cells that is created from these parameters, use the 2DGridCreator. Specify 0,0 for Starting X Coordinate and Starting Y Coordinate, respectively, and the same values for Column Width and Row Height as Neighborhood Width and Neighborhood Height, respectively. |
Minimum Neighborhood Members |
When you set this parameter, neighborhoods with fewer than the specified number of features are merged with a vertical neighbor area in order to increase the number of members. You can prevent this from happening by setting the parameter to 0 (zero). |
Accumulation Mode |
If Drop Incoming Attributes is chosen, the output feature will not preserve any input attributes. If Merge Incoming Attributes is chosen, the output feature will merge all input attributes. If Use Attributes From One Feature is chosen, the output feature will get attributes from only one input feature. |
Generate List
List Name |
If a List Name is specified, then all attributes of an input feature will be stored as part of a list attribute entry in the output feature. Note: List attributes are not accessible from the output schema in FME Workbench unless they are first processed using a transformer that operates on them, such as ListExploder or ListConcatenator. Alternatively, AttributeExposer can be used. |
Add To List |
All Attributes: Every attribute from all input features that created an output feature will be added to the list specified in List Name. Selected Attributes: Only the attributes specified in the Selected Attributes parameter will be added to the list specified in List Name. |
Selected Attributes |
The attributes to be added to the list when Add To List is Selected Attributes. |
Dialog Options - Tables
Search for all results about the NeighborhoodAggregator on the FME Community.
Keywords: MBR "minimum bounding rectangle" Clumper NeighbourhoodAggregator
