MGRSToLatLongConverter
Converts Military Grid Reference System (MGRS) code to longitude and latitude coordinate values.
Jump to Configuration
  • Determining the center point of the area represented by a standard MGRS code.
The MGRSToLatLongConverter accepts any feature. The user specifies an attribute, expression, or user parameter containing a valid MGRS Code, along with the Ellipsoid and appropriate Lettering Type.
The coordinates of the center point of the described area are added as attribute values. The size of the area (and so the position of the center point) depends on the precision of the MGRS code, ranging from 1 meter square to 100 km square. See LatLongToMGRSConverter for more information.
Dialog Options - Tables
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
FME Community
The FME Community is the place for demos, how-tos, articles, FAQs, and more. Get answers to your questions, learn from other users, and suggest, vote, and comment on new features.
Search for all results about the MGRSToLatLongConverter on the FME Community.
