GoogleBigQueryConnector
Accesses the Google BigQuery service to load or query tables from a Google Cloud account.
Jump to Configuration
- Load CSV formatted data into new or existing BigQuery tables
- Query BigQuery tables with the option to load the result to a specified destination BigQuery table
- Create a queryable external table in Google BigQuery that links to existing data on Google Cloud Storage
Google BigQuery is a managed NoSQL database service.
The GoogleBigQueryConnector uses your Google Cloud account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer).
For more information about BigQuery, please visit the Google Cloud BigQuery product page.
Input
Output
The output of this transformer will vary depending on the Request > Action performed.
- After a Load Data action, output will include the following attributes:
_project_id
Name of the project_id loaded into.
_table
Name of the table loaded into.
_dataset
Name of the dataset loaded into.
_rows_written
Number of rows written to the specified table in the dataset.
- After a Query action, output will contain attributes set in the Exposed Attributes parameter, which correspond to the columns from the ran query. Geography functions will output as WKT (well-known text).
Initiator
The incoming feature is output through this port.
<Rejected>
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Note: If a feature comes in to the GoogleBigQueryConnector already having a value for fme_rejection_code, this value will be removed.
Authentication
Credential Source
Credentials can be used from different sources. Using a web connection integrates best with FME but in some cases, you may wish to use one of the other sources.
- Web Connection: Use a Google BigQuery web connection stored in the FME web connections database.
- Service Account Key File: Use credentials already configured on the system, in the key file specified in the environment variable GOOGLE_APPLICATION_CREDENTIALS.
Account
Available when the credential source is Web Connection. To create a Google BigQuery web connection, click the Account drop-down box and select Add Web Connection.
The connection can then be managed via Tools > FME Options > Web Connections.
Project ID
The Google Cloud project id. Only required when the credential source is Web Connection.
Request
Action
The type of operation to perform. Choices include:
- Load Data: load data into BigQuery tables and datasets
- Query: query a BigQuery table and dataset
Parameters - Load Data Action
Data Source
Load Source
Select the type of source data to be loaded:
- File
- GCS Native Table: Copy data from Google Cloud Storage into a Google BigQuery table.
- GCS External Table: Create an external table that links to existing data on Google Cloud Storage. The data is referenced and not copied over to BigQuery.
File to Load
If Load Source is File, specify the location and name of the file to be loaded.
Bucket
If Load Source is Google Storage, specify the Google storage bucket.
Path
If Load Source is Google Storage, specify the Google storage path.
File Type
Only CSV is supported at this time.
Header Rows to Skip
For CSV files, specify the number of rows to skip at the top of the file.
For example, if the file contains a single-line header, enter 1.
Auto Detect Schema
If Yes ,BigQuery will at best effort detect and set the data types of your data.
If No, Defined Schema will be used.
Defined Schema
If Auto Detect Schema is No, define a schema using the following JSON format.
"description": "[DESCRIPTION]",
"name": "[NAME]",
"type": "[TYPE]",
"mode": "[MODE]"
"name": "[NAME]",
"type": "[TYPE]",
"mode": "[MODE]"
For more information, see BigQuery's Specifying a schema documentation.
Load Options
Table Handling
If the specified Destination Table does not exist, it will be created.
If it does already exist, the selected method will be used to load data:
- Overwrite: Replaces all existing data in the table.
- Append: Appends the data to the end of the table.
- Write if Empty: Loads the data only if the table is empty.
Table Handling is not an option when the Load Source is GCS External Table.
Destination Dataset
The dataset of the destination table.
Destination Table
The target table where results are loaded.
Parameters - Query Action
Query Options
Query
The SQL query to run.
Note that when querying the BigQuery type NUMERIC, FME will receive the type fme_string.
Enable Destination Table
If enabled, query results will be stored in a table.
Table Handling
Destination Dataset
Destination Table
Exposed Attributes
Exposed Attributes
The list of attributes to output. Attributes should be the column names of the query.
How to Set Parameter Values
Text Editor
Arithmetic Editor
Dialog Options - Tables
- Add a row
- Remove a row
- Move current row up one
- Move current row down one
- Move current row to top
- Move current row to bottom
- Cut a row - delete and copy to clipboard
- Copy a row to the clipboard
- Paste a row from the clipboard
Cut, copy, and paste may be used within a transformer, or between transformers.
Start typing a string, and the matrix will only display rows matching those characters. Searches all columns. This only affects the display of attributes within the transformer - it does not alter which attributes are output.
Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies |
Google Cloud Storage Account
Aliases |
History |
Released FME 2019.1 |
The is the place for demos, how-tos, articles, FAQs, and more. Get answers to your questions, learn from other users, and suggest, vote, and comment on new features.
Search for all results about the GoogleBigQueryConnector on the .
