DEMDistanceCalculator
Calculates the distance between a number of input vector lines and the elevation values of a reference DEM raster, and outputs a new DEM raster per input line.
The data contained in the resulting DEM consists of the 3D distance between the line being considered and the corresponding point on the reference DEM.
This transformer supports raster band and palette selection. The RasterSelector can be used to modify selection.
A reference DEM raster. Only the first raster feature received for each Group By grouping will be used.
3D line features.
Raster DEMs representing the 3D distance between a line and the corresponding point on the reference DEM.
Any input features entering the Line port that are not 3D lines will be rejected with the fme_rejection_code attribute set to INVALID_VECTOR_GEOMETRY_TYPE.
Any input features entering the RefDem port that are not valid DEM rasters will be rejected with the fme_rejection_code attribute set to INVALID_REF_RASTER_GEOMETRY.
If more than one DEM raster is received for a Group By grouping, the extra rasters will be rejected with the fme_rejection_code attribute set to EXTRA_REF_RASTER_FEATURE.
Group By |
Use this parameter to organize lines into groups, with each group of lines having its own reference DEM. |
Complete Groups |
![]() There are two typical reasons for using When Group Changes (Advanced) . The first is incoming data that is intended to be processed in groups (and is already so ordered). In this case, the structure dictates Group By usage - not performance considerations. The second possible reason is potential performance gains. Performance gains are most likely when the data is already sorted (or read using a SQL ORDER BY statement) since less work is required of FME. If the data needs ordering, it can be sorted in the workspace (though the added processing overhead may negate any gains). Sorting becomes more difficult according to the number of data streams. Multiple streams of data could be almost impossible to sort into the correct order, since all features matching a Group By value need to arrive before any features (of any feature type or dataset) belonging to the next group. In this case, using Group By with When All Features Received may be the equivalent and simpler approach. Note: Multiple feature types and features from multiple datasets will not generally naturally occur in the correct order. As with many scenarios, testing different approaches in your workspace with your data is the only definitive way to identify performance gains. |
Dialog Options - Tables
Search for all results about the DEMDistanceCalculator on the FME Community.
Keywords: raster band palette vector distance DEM
