AttributePivoter
Restructures and regroups incoming features based on specified Group By attributes and calculates summary statistics to form a Pivot table output.
- Calculating statistics on tabular data
The AttributePivoter receives features with attributes, restructures and regroups them based on specified Group By attributes, and calculates summary statistics based on a designated Attribute To Analyze in order to form a Pivot table output.
Like the StatisticsCalculator, the AttributePivoter groups features according to selected attributes, and computes statistics on a single attribute for all features in each group (Grouping by rows). Beyond this, the AttributePivoter allows for the order of these row grouping attributes to be specified so that a logical nesting of additional summary rows can be generated. In addition, the AttributePivoter also allows for new attributes to be generated dynamically based on the unique values of a selected attribute (Grouping by Column) with values populated by statistics performed on the resultant groupings.
Note: Because the AttributePivoter generates attributes dynamically, you must set any writer feature types to dynamic mode if you want to include these attribute in the output. This is described in more detail in Result Grouping and Tabular Structure.
Group Rows By and (optionally) Group Columns By define a logical nesting of row groups.
For each such logically nested group, the AttributePivoter computes summary statistics, which it emits as table rows through the Summary port. The value for the most specific row grouping attribute for the summary row is given a value of “<attrName> <description>”, where <attrName> is the name of the row grouping attribute, and <description> is the value given to the “Row Group Summary Line Description” parameter.
For example, if grouping by an attribute called “Region_RSS”, the summary row over all regions would have a value of “Region_RSS Total” for the “Region_RSS” attribute, assuming the row group summary line descriptor is left with the default value of “Total”.
Input features are grouped by “grouping attributes”, and statistics are computed on the specified analyzed attribute in each group. There are two kinds of grouping attributes which work together to define these groups:
- Row Grouping Attributes: The user specifies an ordered set of attributes that divide the statistics into rows. There is a single row of result data for each unique set of values for the specified set of row grouping attributes.
- Column Grouping Attribute: The user can optionally specify a single attribute to define columns in the resulting rows. If specified, each unique value of the column grouping attribute contributes a column of statistical data to the result, for each statistic being computed. Additionally, if there is more than one unique value for the column, a summary column will be generated for each statistic.
If no column grouping attribute is selected, each row will contain a single computed result for each selected output statistic.
Because the row grouping attributes are ordered, they effect a logical nesting of groups. At the lowest level, a complete set of unique values is represented as a single row of the result. One level up is the logical grouping consisting of the set of rows where all row grouping attributes are unique except for the last one specified. This logical nesting carries up to the first specified row grouping attributes.
A row resulting from a complete set of unique data values is known as a “data row”. There is an additional “summary row” generated for each logically nested grouping, which summarizes the data for the data rows contained in the grouping.
The sequence of resulting rows form a table with the following attributes:
- All of the row grouping attributes, whose combined values specify the actual group
- For each pivot summary type, an attribute with the corresponding statistic, computed over all features in the row group.
- If there was more than a single column group defined, each of the attributes in (2.) will be repeated for all column groups, along with a summary value (that is, a “grand total”) computed over the attribute values over all column groups. The method for computing the summary value depends on the statistic it is representing:
- Count and Sum statistics are summarized with the sum of the computed statistics for the row group.
- Average statistics are summarized with the average of all values in the row group.
- Min values are summarized by the minimum of all occurrences of the analyzed attribute for the group.
- Max values are summarized by the maximum of all occurrences of the analyzed attribute for the group.
The first data feature and first summary feature emitted will contain additional attributes containing the schema information needed to write the data out by a feature type configured for dynamic writing.
In this example, we start with a simple CSV table of statistics to be pivoted and analyzed. The CSV features are routed into an AttributePivoter.
In the parameters dialog, we choose to Group Rows By region, then potential. The order is important.
The Attribute to Analyze is observed - the column containing our statistics. We have requested Count, Sum, and Average calculations.
The output (via a dynamic Excel writer) now contains the added statistics.
- The AttributePivoter can only be used to analyze one attribute at a time. If you need to analyze more than one attribute, consider the StatisticsCalculator.
Features with attributes for analysis.
A single new feature will be output containing all computed statistics for each completely defined row group. The attributes on these features are described in the “Result Grouping and Tabular Structure” section.
The first row emitted from the Data port will contain information to define the schema for a dynamically configured feature type.
For each logically nested grouping as described in the “Result Grouping and Tabular Structure” section, a summary row will be emitted prior to the first data row for the group. It provides summary information for all rows contained in the group. An overview summary of all rows will always be generated.
The first row emitted from the Summary port will contain information to define the schema for a dynamically configured feature type.
Group Rows By |
One or more attributes are chosen to specify how features are grouped to form the rows of the resulting table. Unlike most “Group By” parameters, the user has the opportunity to specify the order of the grouping attributes, so that nested summary groupings can be generated, adding a hierarchical structure to the resulting table. |
Group Columns By |
Optional: In addition to row groups, the user can select an attribute whose unique values will generate new attributes, hence “pivoting” the data and further subdividing the groupings on which the statistics are calculated. |
Attribute to Analyze |
A single attribute is chosen upon which to compute statistics. The features are grouped according to the row and column grouping attributes, and statistics are calculated over all values of this attribute within the features in each group. |
Pivot Summary Statistic Types |
The user can choose to compute multiple types of summary statistics simultaneously. Each chosen statistic type will be represented as a separate column within each column group of the result table. One or more of the following statistic types may be selected.
Row Group Summary Line Descriptor |
Enter a name for the Summary line of each Row Group. The default descriptor is Total. |
Dialog Options - Tables
Yes |
Dependencies | None |
Aliases | |
History |
Search for all results about the AttributePivoter on the FME Community.
