Oracle Spatial Object Reader/Writer
FME can read and write geometric and attribute data stored using Oracle Spatial.
This module communicates directly with Oracle Spatial for maximum throughput.
Using FME with Oracle Formats
Oracle Format Data Type
Oracle Non-Spatial Reader/Writer
attributes only
Oracle Spatial GeoRaster Reader/Writer
raster
object relational model (referred to as the object model)
Oracle Spatial Point Cloud Reader/Writer
point cloud
Oracle Spatial Relational Reader/Writer
relational model
Oracle Spatial Product and System Requirements
Format
FME Platform
Operating System
Reader/Writer
FME Form
FME Flow
FME Flow Hosted
Windows 64-bit
Linux
Mac
Reader
Yes
Yes
Yes
Yes
Yes
Yes
Writer
Yes
Yes
Yes
Yes
Yes
Yes
Format Notes
Oracle and FME
Description
3D Geometry Support
Reading and writing of 3D surfaces and solids is available only for Oracle 11g and above.
Oracle Instant Client
Instant Client can be used to run your OCI, OCCI, JDBC, and ODBC applications without installing a full Oracle Client. Instant Client supports SQL*Plus.
See the FME Community for more information on how Instant Client works with FME.
Oracle Wallet
To use an Oracle Wallet with FME, leave the Username and Password parameters empty, and enter the name of the Oracle Wallet as the value of the Service Name or Easy Connect parameter.
Supporting Very Large Geometries
By default, Oracle Spatial can only support geometry with less than 1,048,576 ordinates.
Note  For more information about supporting larger geometries, see Increasing the Size of Ordinate Arrays to Support Very Large Geometries in the Oracle Spatial Developer's Guide.
Reader Overview
The Oracle Spatial Object reader reads attributes and geometry from Spatial tables in an Oracle Spatial Database.
Writer Overview
The Oracle Spatial Object writer module stores geometric and attribute data in an Oracle Spatial database. Both uppercase and lowercase table names are supported. The writer supports the following features:
Feature
Description
Transaction Support
Provides transaction support that eases the data loading process. Occasionally, a data load operation terminates prematurely due to data difficulties. The transaction support provides a mechanism for reloading corrected data without data loss or duplication.
Table Creation
Uses the information within the FME workspace to automatically create database tables as needed.
Table Dropping
Allows each table to be written to be dropped if recreating, or truncated if appending.
Index Creation
Sets up and populates all needed indexes and index tables as part of the loading process.
Bulk Loading
Uses a bulk loading technique to ensure speedy data load.
