Esri Mobile Geodatabase Reader/Writer
FME can store data in and retrieve data from Esri Mobile Geodatabase.
A mobile geodatabase (.geodatabase) is a collection of various types of GIS datasets contained in a single file on disk that can store, query, and manage spatial and nonspatial data.
Mobile geodatabases contain system tables, indexes, triggers, and views that provide geodatabase functionality to work with simple features such as point, multipoint, multipatch, polygon, line geometries, and true curves.
See Esri Mobile Geodatabase Quick Facts for information.
FME supports a range of Geodatabase types. For detailed information about Geodatabases, see the Esri Geodatabase Overview.
Esri Geodatabase Types
A geodatabase is a container used to hold a collection of datasets. There are different types of geodatabases:
File Geodatabases
A file geodatabase is stored as multiple files in a folder with a .gdb extension. Each dataset is contained in a single file.
File Geodatabases
Format Identifier
Reader
Writer
Esri Geodatabase (File Geodb)
GEODATABASE_FILE
Esri Geodatabase (File Geodb) Reader Parameters
Esri Geodatabase (File Geodb) Writer Parameters
Esri Geodatabase (File Geodb Mosaic Dataset)
GEODATABASE_FILE_MOSAIC_DATASET
Esri Geodatabase (File Geodb Mosaic Dataset) Writer Parameters
Esri Geodatabase (File Geodb Raster Catalog)
GEODATABASE_FILE_RASTER_CATALOG
Esri Geodatabase (File Geodb Raster Catalog) Reader Parameters
Esri Geodatabase (File Geodb Raster Dataset)
GEODATABASE_FILE_RASTER_DATASET
Esri Geodatabase (File Geodb Raster Dataset) Reader Parameters
Esri Geodatabase (File Geodb Raster Dataset) Writer Parameters
Mobile Geodatabases
A mobile geodatabase is stored in an SQLite database that is entirely contained in a single file and has a .geodatabase extension.
Mobile Geodatabase
Format Identifier
Reader
Writer
ESRI_MOBILE_GEODATABASE
Esri Mobile Geodatabase Reader Parameters
Esri Mobile Geodatabase Writer Parameters
Enterprise Geodatabases
Enterprise geodatabases are stored in relational databases. They can be virtually unlimited in size and number of users.
Format Identifier
Reader
Writer
Esri Geodatabase (ArcSDE Geodb)
GEODATABASE_SDE
Esri Geodatabase (ArcSDE Geodb) Reader Parameters
Esri Geodatabase (ArcSDE Geodb) Writer Parameters
Esri Geodatabase (ArcSDE Geodb Mosaic Dataset)
GEODATABASE_SDE_MOSAIC_DATASET
Esri Geodatabase (ArcSDE Geodb Raster Catalog)
GEODATABASE_SDE_RASTER_CATALOG
Esri Geodatabase (ArcSDE Geodb Raster Dataset)
GEODATABASE_SDE_RASTER_DATASET
FME Community
