Removing Unattached Objects
                                                To quickly remove unattached objects:
                                                    - Select Tools > Remove
 Unattached. A list of unattached objects appears.
                                                    - For large lists, use the search filter to display
                                                    - Use the checkboxes to delete the selected objects,
 and click OK.
